TwinTurbo.NET: Nissan 300ZX forum - Could a failed FPR in the closed position cause enough...
msb1987
on January 05, 2015 at 10:21 PM
How can my car run run with all the injector connectors
posted by msb1987
on January 05, 2015 at 06:43 PM
pressure to force fuel through the injectors? That is the first thing I can think of. Second thing, why did it keep running after I turned off the ignition? What was producing the spark?
msb1987
18:43:40 01/05/15
Could a failed FPR in the closed position cause enough... -
msb1987
22:21:37 01/05/15
I saw your earlier post. From what you wrote of your
doug8867
22:41:30 01/05/15
Thanks for the reply and that is what I was thinking when
msb1987
22:54:48 01/05/15
Does it 'run', or is it run-on
-Grimm-
01:03:48 01/06/15
Honestly I could not tell you. I was so shocked when it
msb1987
07:15:24 01/06/15
Re: How can my car run run with all the injector connectors
MaxxAction
10:11:35 01/06/15
No change or upgrade. Maybe I'm wrong but isn't very..
msb1987
10:29:36 01/06/15
Re: No change or upgrade. Maybe I'm wrong but isn't very..
MaxxAction
11:06:13 01/06/15
So what would your next move be? Thanks for the help. (n/m)
msb1987
11:40:23 01/06/15
Re: So what would your next move be? Thanks for the help.
MaxxAction
11:53:50 01/06/15
Car on, means key turned to on or...
msb1987
13:19:47 01/06/15
So apparently my car achieved the holy grail of
msb1987
14:01:52 01/06/15
Solved or at least part of it...
msb1987
19:27:31 01/06/15
http://z32.wikispaces.com/Fuel+Injector+Replacement (n/m)
ThisIsSparTTa
12:00:29 01/07/15
Prepare for a lot of work
-Grimm-
12:40:55 01/07/15
why is it in the plenum though???? anyone
LivinTheDream
09:56:50 01/08/15
^Yeah
-Grimm-
11:39:51 01/08/15
